Hi Everyone, I am trying to install xibo 3.x.x on a synology…
I copied the xibo folder in the web folder of my synology…then I created a vhost like in the picture. But now I’m not quite sure what the path to the DokumenRoot must be??? /web/xibo or /web/xibo/web ??? Does anyone know?
What do I have to enter in the browser then??? DS918/xibo or DS918/web/xibo or DS918/web/xibo/web ??? None of them works…I always get a 404 error
Would be great if someone here in the board could explain me exactly what I have to enter in the browser and how the path must be called correctly for the document root? Thanks
the content of the DkumentRoot I have not changed…do I have to change there possibly also what still with the #???
While that may be true, you are using a legacy installation method that is not favored and most of the community does not use. You are setting yourself up for future challenges if you continue down this path. Would recommend going with Docker.
To my point, I’ve never setup Xibo without Docker so I cannot provide you any support.
Ok is there a step by step installation video from the xibo team on how to install xibo in Docker on a Synology? I have not found anything on the net, neither on YouTube nor here in xibo
One question: now, i habe installed Version 3.0.5.
Please can you send me a Link what Player for Windows Workshop Fine with this xibo cm/s?
The thing is that running docker on synology requires an extra step. You need to point the volume on your Synology so it can write files and database to it. This way you are able to remove a specific (old version) of the docker app (Xibo) and just download the new one. It will start with the same docker config and database.
I am using Portainer (next to docker) so I can have a overview of the running apps.
I have had issues with a local CMS of Xibo, now running with Docker is faster/smoother and for support easier to help you out with support.
Can you tell me how you setup Xibo with docker?
I installed the container but it doesn’t work. I can sent you the pictures of containers in docker. Thanks
I don’t have a manual available for running Xibo on Docker. I am hosting Xibo on a VPS with Docker. But try a different manual and just add xibo to it.
Running on Synology is more challenging because the Docker CLI is behind sudo and there is no docker-compose, which is required for the standard Xibo installation. I would agree with @Vishal_Debipersad that Portainer is the way to go. Install Portainer, add a stack, drop in the Xibo-provided Docker Compose file, set your paths, and you should be good to go.
