Xibo in large format panels
I’m starting a project with large format LED panels and I want to install a player with Android and Xibo, but I would like to know if it will be possible to use it on 6 x 3 meter LED panels instead of a computer or some other hardware with the Novastar.
I’m already a Xibo user and I want to keep Xibo in my large format Panels project.
Yes, it’s very possible. Create a template with the same resolution as your Nova sender. Create a region in your template that is the same pixel count as your LED display. Use your template to create layouts as usual.
We run some LED advans, we have 3 ‘screens’ (driver, rear, passenger) that are actually 3 regions.
Yes you can.
We have several led panels with novastar mtcrl 300 and another one with nova vx 1000.
We use Android xibo player in 1920 X 1080 resolution.
All you have to do is set the resolution of your player in the cms regarding your led panel resolution.
And finaly, create a layout with the player resolution for your content.
