I would like to change the Theme of the Web UI to match the school im working in.
Is there any way to do this simply?
Have a look here http://xibo.org.uk/manual/en/advanced_theme.html
Spring Signage also offers White Label CMS for 150GBP+VAT(if applicable), which will let you customise the CMS theme.
if there any way for me to edit it my self, if so what files do I edit?
I would like to change this icon for another
Any help would be appreciated ![]()
Hi Peter, can I look simple template example for Xibo by Spring Signage?
