Xibo for webOS v4 R415 Released
We have just released our latest Xibo for webOS release. This release comes with 3 features, 3 enhancements, and 8 fixes.
Features
  • Logging: Added a new option to clear XMR statistics and logs
  • Player: Send status information without requesting a screenshot
  • UI: Improved visibility of error messages
Enhancements
  • Logging: Improved the Status page to display executed system commands
  • SSP Connector: Improved stability and reliability of the SSP Connector
  • UI: Enhanced the Settings screen and the layout player to better support wide and stretched monitor resolutions
Fixes
  • Interactive: Fixed bug with navigate to previous layout
  • Interactive: Resolved an issue preventing layouts with a drawer component from expiring correctly
  • Library: Resolved a problem causing library files to duplicate on player startup
  • Media: Fixed an issue where the player did not properly refresh dataset based widgets
  • Media: Player hangs when downloading last media file
  • Player: Fixed an issue where the display would unexpectedly return to the connection page after de-authorization
  • Player: Fix Purge All functionality on displays with webOS 6.0 or newer
  • UI: Fixed an issue occurring when refreshing the authorization code in the CMS settings screen
Please note that webOS 8.0 models are not supported. Support is pending firmware updates from LG.
Download
Use the link to Download webOS v4 R415.
Visit our Downloads page for all the latest releases.
Install / Upgrade
Installation instructions can be found here.
Instructions for upgrading from an earlier release can be found here.
If you have a white label build of the application, the upgrade is available in the White Label section of your My Account dashboard.
Further guidance on updating your white label player can be found here
Feedback
Please leave any feedback below.
