Hi, i have try this version and i try to compile it.
I am sorry but the problem with video is not resolve like you say.
I have error code 11 and 1
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 0# signalStacktraceHandler(int) in /snap/xibo-player/108/bin/player
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 1# 0x00007FF464534FD0 in /lib/x86_64-linux-gnu/libc.so.6
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 2# 0x00007FF456A0E618 in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 3# 0x00007FF456A436DA in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 4# 0x00007FF456A43E28 in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 5# 0x00007FF45670B81D in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 6# 0x00007FF45677619D in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 7# 0x00007FF456AA1046 in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 8# 0x00007FF456701622 in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 9# 0x00007FF45670261C in /var/lib/snapd/lib/gl/libnvidia-glcore.so.340.108
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 10# _attach_renderbuffer at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglframebuffer.c:434
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 11# gst_gl_framebuffer_attach at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglframebuffer.c:473
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 12# gst_gl_framebuffer_new_with_default_depth at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglframebuffer.c:249
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 13# _init_convert_fbo at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglcolorconvert.c:2262
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 14# _init_convert at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglcolorconvert.c:2198
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 15# _do_convert at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglcolorconvert.c:2486
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 16# _gst_gl_context_thread_run_generic at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglcontext.c:1541
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 17# _run_message_sync at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglwindow.c:575
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 18# _run_message_async at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglwindow.c:642
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 19# g_main_context_dispatch in /snap/xibo-player/108/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 20# 0x00007FF46603C650 in /snap/xibo-player/108/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 21# g_main_loop_run in /snap/xibo-player/108/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 22# gst_gl_window_default_run at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglwindow.c:501
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 23# gst_gl_window_run at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglwindow.c:523
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 24# gst_gl_context_create_thread at /build/xibo-player/parts/gst-plugins-base/build/gst-libs/gst/gl/gstglcontext.c:1307
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 25# 0x00007FF466064175 in /snap/xibo-player/108/usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 26# start_thread in /lib/x86_64-linux-gnu/libpthread.so.0
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: 27# __clone in /lib/x86_64-linux-gnu/libc.so.6
Dec 10 10:04:07 fst-o-f-xibo2 xibo-player[7831]: Player exited with code 11
Dec 10 10:04:10 fst-o-f-xibo2 xibo-player[7831]: [10:04:10.675] [8667] [error]: [DBus] ScreenSaver wont'be suspended: org.freedesktop.DBus.Error.Spawn.ExecFailed
Dec 10 10:04:11 fst-o-f-xibo2 player[8667]: g_dbus_proxy_new_sync: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
Dec 10 10:04:49 fst-o-f-xibo2 player[8667]: player: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Dec 10 10:04:49 fst-o-f-xibo2 xibo-player[7831]: Player exited with code 1
Dec 10 10:04:53 fst-o-f-xibo2 xibo-player[7831]: [10:04:53.057] [8761] [error]: [DBus] ScreenSaver wont'be suspended: org.freedesktop.DBus.Error.Spawn.ExecFailed
Dec 10 10:04:53 fst-o-f-xibo2 player[8761]: g_dbus_proxy_new_sync: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
Dec 10 10:05:16 fst-o-f-xibo2 player[8761]: player: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Dec 10 10:05:16 fst-o-f-xibo2 xibo-player[7831]: Player exited with code 1
Dec 10 10:05:19 fst-o-f-xibo2 xibo-player[7831]: [10:05:19.257] [8831] [error]: [DBus] ScreenSaver wont'be suspended: org.freedesktop.DBus.Error.Spawn.ExecFailed
Dec 10 10:05:19 fst-o-f-xibo2 player[8831]: g_dbus_proxy_new_sync: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
my conf :
snap 2.48.1
snapd 2.48.1
series 16
ubuntu 18.04
kernel 4.15.0-122-generic
Nom Version Révision Suivi
core18 20200929 1932 latest/stable
gnome-3-28-1804 3.28.0-19-g98f9e67.98f9e67 145 latest/stable
gtk-common-themes 0.1-50-gf7627e4 1514 latest/stable
multipass 1.5.0 2907 latest/stable
snapcraft 4.4.4 5821 latest/stable
snapd 2.48.1 10492 latest/stable
xibo-player 1.8-R6 108 latest/candidate
