dan
April 8, 2020, 1:55pm
1
Hi all,
We have a new revision of Xibo for Linux in the edge channel if anyone is able to test. It builds on the fixes we’ve already got in Revision 46, and improves error logging capability.
Specifically these 3 things have been addressed:
opened 11:52AM - 11 Oct 19 UTC
Player Version: 1.8 R3-28
Issue: The following error is regularly returned on the Player, even after XMR has been reconfigured:
[029193] [error]: [XMR]...
bug
opened 04:21PM - 17 Feb 20 UTC
If a transition definition is invalid - for example we have flyOut without a direction, we should default the direction rather...
bug
opened 03:14PM - 18 Feb 20 UTC
Player logs this:
[07:22:01.187] [12279] [error]: [XiboApp] Error while upadting settings: [WidgetGtk] Size should be non-negative
[07:22:01.265] [12279] [error]: [Main] [WidgetGtk] Scale factor...
bug
Feedback welcome as always!
Thanks!
Best wishes,
Dan
dan
Closed
July 8, 2020, 7:55pm
2
