Xibo for Android v4 R411 Released
Hi everyone,
We have just released our latest Xibo for Android release. This release comes with seven enhancements and fixes.
Enhancements & Fixes
  • Config: better compatibility with non 16:9 resolutions (e.g. shelf edge)
  • Logs: it is possible to send the status screen content separately from a screenshot
  • Stability: various stability improvements for 24/7 operation
  • Stability: fix ANR on rooted devices
  • Video: fallback to software decoding when the device hardware decoder is in error state
  • Widget: display tags are available inside web based widgets (xiboIC.get('displayTags');
  • Widget: when new data is received by the app, it will notify currently playing widgets so they can update themselves
Download
Use the link to Download Xibo for Android v4 R411.
Visit our Downloads page for all the latest releases.
Install / Upgrade
Installation instructions can be found here.
Instructions for upgrading from an earlier release can be found here.
If you have a white label build of the application, the upgrade is available in the White Label section of your My Account dashboard.
Further guidance on updating your white label player can be found here.
Feedback
Please leave any feedback for this release.
In the last two or three versions, I kept getting a daily notification in the CMS that the players hadn’t reported in on time (this never affected the players themselves).
Since version 411, this problem seems to have been resolved! Thank you!
