Xibo for Android v4 R408 Released
Hi everyone,
We have just released our latest Xibo for Android release. This release comes with two enhancements and two fixes.
Enhancements
  • SSP: Improved request rate for ads leading to a more reliable ad delivery percentage
  • XMR: Connect to XMR via a WebSocket on CMS instances of 4.2 and later
Issues
  • Commands: Fix the error ‘class com.google.common.reflect.TypeToken isn’t parameterized’ which causes Commands and Display Tags not to function
  • Logs: Fix the error ‘SQLLite: Attempt to re-open an already-closed object’ which occurs when some devices go into standby mode
Download
Use the link to Download Xibo for Android v4 R408.
Visit our Downloads page for all the latest releases.
Install / Upgrade
Installation instructions can be found here.
Instructions for upgrading from an earlier release can be found here.
If you have a white label build of the application, the upgrade is available in the White Label section of your My Account dashboard.
Further guidance on updating your white label player can be found here.
Feedback
Please leave any feedback for this release below.
Hello!
A suggestion:
For those with White Label (like me), it would be great to have options to replace the new assets in this new XFA view.
  • Change the button colors
  • Change the image on the CMS connection screen
Another thing that would be even more useful:
Being able to choose which keys/buttons will trigger the settings. For example:
  • Key “i” – Status screen
  • Key “c” – CMS connection
  • Etc.
This should be customizable for those who have the White Label.
Is this possible?
Thank you!
Hello, I guess you can refer here: White Labelling | Xibo Digital Signage
