I haven’t tested it yet, but I saw that support for Android TV was added in version R403. My question is now, is it possible to perform automatic startup via Android TV? Lu will still depend on starting the app manually or using a ready launcher like LauncherHijack
So depending on your display you can set the startup function to be xibo and the home function to launch an android application > xibo.
On my sony consumer TV, xibo launches after whatever the time frame you have set in the display settings.
