We are using Xibo Android 1.8 R104 and CMS 1.8.13 with no special problems at all, but we want to update Android devices with latest version. One reason is that sometimes we have blocking problems at random time and display. The content randomly stops playing and hold one layout continoulsy.
The problem is when we update release to 1.8 R108 (hoping bug resolved) the display lost connection and never again connects to CMS. Also tested with v2 R201.
Neither updated via CMS nor manual installation.
Only appears connected when manually clicks “Connect to CMS” after installation, never again.
I suggest you bring up the player’s status screen by clicking anywhere on the screen, then at the top.> Status and scroll down to check Licence and Registered
If it says false on Registered, please scroll down to the end to check the last 5 logged messages.
Alternatively you can send us screenshots of the whole Status Screen and send it to our support email.
I can see in your screenshot that the Next Scheduled Update is in 2000. Can you confirm that the time and date are set correctly in the Android system settings?
I’ve just updated Xibo from R104 to R108 and it begins to fail. I can connect to the CMS by clicking “Connect to CMS” and player appears connected. After 5 minutes (the configured refresh interval), player returned to appear offline and never again reconnects.
Player has Internet access and network is correctly up…
Thank you for the screenshots. According to the error logs you have provided, the Player is confirming that it does not have a network connection and so is unable to connect to your CMS. Your screenshots are quite limited and do not provide any time stamps so I have no idea how old these logs are.
You mentioned that the Player appears connected to your CMS when you enter the CMS credentials in Connect to CMS, can you confirm what you are seeing that makes you think they are connected? What does the Display entry look like in your CMS, is it showing as up to date?
You didn’t respond to my question about making sure that the time and date are set correctly on the device running your Player. Can you confirm they are set properly?
Can you provide a full status screenshot? You can always edit the photo so that any info you want to keep private is hidden or send it to me in a private message. Without being able to see more than you are providing, it is hard to tell when you are getting these errors and if there are any other logs that could explain your issue.
Please also let me know if this is a Wifi or wired network connection.
We use an android player with wired connection (RJ45) and static IP.
Time and date seems ok. Internet navigation it’s ok. If I click “Connect to CMS” it connects to CMS and appears online (cms connected tick) for 5 minutes, after that becomes offline again.
Seems like only Connect to CMS method uses network connection okay, but not the periodic update check.
That problem not exists in release R104, so… what is the difference between the two releases?
Thank you for your reply, no need to apologise for the delay.
I can see 2 things in the Status screenshot you provided that will need to be addressed. The first is that the Player has not been registered in your CMS. This is quite unusual as you appear to have a large number of Events scheduled to this Player, yet it is not Authorised. Did you de-authorise the Player after you scheduled Events for it?
The second issue you have appears to be related to your network. You have errors stating that the Network connection is down/disconnected, so the Player is unable to connect to your CMS.
There are no differences between the R104 and R108 that would explain why your Player fails to connect to your CMS, nothing has changed about the APK that would affect that. Are there any security devices on your network that may be stopping the Player from connecting to your CMS?
Of course not, player was authorised months ago, so it have content downloaded.
I have the displays automatic authorization setted on CMS too.
This message dissapears when I click “Connect to CMS” and returns after 5 minutes (configured updating time). Display seems always authorised on CMS. (tick icon)
Negative. We have more a more players connected identically and they work perfectly, all with version R104…
Thank you for answering my questions about this issue. Can you also confirm if your other players are on the same network as the Player you are having an issue with?
Thanks for confirming. At this point I would be interested to see what happens when you uninstall the R108 Player on that device and reinstall R104. Could you do this and report if the issue is indeed not occurring on this device once you return to using the R104 Player please? I can then discuss this difference with my colleagues.
Could you also confirm if the Player is set to run as Launcher? If it is, could you change the setting so that it does not?
To do this, go to the System settings for Android and select the Home option. Make sure that you do not have Xibo set as Home. After you have done this, can you try the Player again please to see if there is any change?
Thank you for changing the setting and sorry to hear that it has not resolved the issue. Are all of your devices running the Xibo Player the same make and model, as well as running the same version of Android and with the same Firmware version?
Hi Dan, yes, of course. All devices are the same.
I think is not a device problem, because the R108 does not work on any device, but if I install R104 works on all devices, this is the version we have in production now.
