Just fooling around with the Android app however I can’t seem to connect to the CMS.
It always says ‘can’t connect to this cms’. Everything does work with a windows client (as i’m trying to connect to an existing xibo instance). Key is also correct and obviously, i’m able to access everything through a browser.
I’m running on xibo 1.8.10 and the latest xibo for android client.
Any suggestions on where i can look to troubleshoot this issue?
Without knowing how your network is setup, it’s hard to say, but Xibo for Android can definitely connect via hostname.
As it works by IP, it suggests you have a DNS resolution issue there somewhere - either the Android device can’t resolve the server name, or it doesn’t have access for some reason via name.
You’re welcome to sign up for a demo Cloud CMS to prove the Player side works as expected.
Make sure that SSL is correctly setup. Use Qualys SSL labs to run a test, and particularly ensure that you have no certificate chain issues, and that the protocols you have enabled are compatible for Android.
Check too that the load balancer is preserving the Host http header, and is adding the standard reverse proxy X-Forwarded-* headers as expected.
