when i set the storage location between these two options below :
internal storage
external storage
After get player running, I’m still cannot find any folder/path where the downloads files and resources have been collected by xibo system on my-android-player
Cause i want to make sure any downloads files and resources have been collected successfull
I believe the end of the path will be /data/data/uk.org.xibo.client/files
no matter if it’s emulated/actual sd card or internal storage, you can also search for Xibo (or uk.org.xibo.client), as I assume you do have some sort of file manager installed on the android device.
Players also reports the media inventory status to the CMS, that’s another way to check if it really did download everything it needs.
Currently, i’m still cannot find the Xibo at /data/data/uk.org.xibo.client/files
and after follow your suggestion using File Manager with searching-files features
I get all file xibo-files saving at /Android/data/com.signage.zrgpirolcu/files
If i read the path name, it’s seem little bit strange name
Can you explain why all my xibo files have been gathered to this filepath ?
