xibosignage/xibo-cms:release-3.3.6
xibosignage/xibo-cms:release-4.0.0-alpha2
Installation Method
Operating System
Host Docker engine on MacBook PRO M2 ( arm64 )
It seems to fail here:
I think you need to make sure the user you’re using for docker has permission to white that folder. For example using root or sudo docker-compose up -d You can always just destroy that container and try again.
