Im using latest xibo docker version , after i checked all posts about xibo rtl , i didnt find any solution .
so i decided to create a new topic about how can i make my dashboard RTL except langauge i mean just want to know how can i move navbar to the right and content to the left without any future issue
If you go to the Settings option in your CMS, you should find under the Configuration tab that you have the option to move the Navigation bar to the top or left of the screen, as shown in my screenshot below:
