Installation Method
Docker
Operating System
Win10 ver 1903
Xibo continuously crashes which requires a full docker restart to fix, and then it happens again with 5 minutes. I am unsure what is causing the crash as each time to restart fixes it for a temporary period. The logs are not specific in what the issue is. When the crash happens I am unable to pull up the xibo log in page in the browser. Please advise.
Log:
2020-05-26 13:25:15 1 [Note] InnoDB: Database was not shutdown normally!
cms-db_1 | 2020-05-26 13:25:15 1 [Note] InnoDB: Starting crash recovery.
cms-db_1 | 2020-05-26 13:25:15 1 [Note] InnoDB: Reading tablespace information from the .ibd files…
cms-db_1 | 2020-05-26 13:25:16 1 [Note] InnoDB: Restoring possible half-written data pages
cms-db_1 | 2020-05-26 13:25:16 1 [Note] InnoDB: from the doublewrite buffer…
cms-db_1 | 2020-05-26 13:25:16 1 [Note] InnoDB: 128 rollback segment(s) are active.
cms-db_1 | 2020-05-26 13:25:16 1 [Note] InnoDB: Waiting for purge to start
cms-db_1 | 2020-05-26 13:25:16 1 [Note] InnoDB: 5.6.48 started; log sequence number 5464755
cms-db_1 | 2020-05-26 13:25:17 1 [Note] RSA private key file not found: /var/lib/mysql//private_key.pem. Some authentication plugins will not work.
cms-db_1 | 2020-05-26 13:25:17 1 [Note] RSA public key file not found: /var/lib/mysql//public_key.pem. Some authentication plugins will not work.
cms-db_1 | 2020-05-26 13:25:17 1 [Note] Server hostname (bind-address): ‘*’; port: 3306
cms-db_1 | 2020-05-26 13:25:17 1 [Note] IPv6 is available.
cms-db_1 | 2020-05-26 13:25:17 1 [Note] - ‘::’ resolves to ‘::’;
cms-db_1 | 2020-05-26 13:25:17 1 [Note] Server socket created on IP: ‘::’.
cms-db_1 | 2020-05-26 13:25:17 1 [Warning] Insecure configuration for --pid-file: Location ‘/var/run/mysqld’ in the path is accessible to all OS users. Consider choosing a different directory.
