Xibo CMS v4.4.2 Released
Hi everyone,
We have released our second patch release of v4.
Enhancements and fixes
4.4.2 introduces 15 enhancements and fixes.
You can find information on what has changed and additional assets on GitHub, or by using the links below.
Download
Please use the links below to download this release:
Visit our Downloads page for all the latest releases.
Change Log
Detailed changes for this release here.
Install / Upgrade
Instructions for installation/upgrade can be found here.
The minimum version of PHP needed to run the CMS is PHP 8.1.
Please note: Xibo 4.4 does not require ZeroMQ/ZMQ dependencies for the web container, making it easier to install for those of you not using Docker. See the Apache/IIS notes for more information.
Players
We recommend using player software of the same version as your CMS. The latest player software is available here.
Earlier versions of the player will connect to a v4 CMS in legacy mode.
Please note: Xibo for webOS and Xibo for Tizen players require v3 R308 and above to function with a v4 CMS. View the latest player software here.
Cloud hosted
If you have a cloud hosted CMS and have not opted out of minor version updates, this update will be applied to all v4.3 instances onwards.
Feedback
Please let us know what you think of v4.4.2.
