Hi everyone,
As we continue to refine v4.3, we have released Xibo v4.3.1 today. This release includes 25 enhancements and fixes:
Command: HTTP trigger command adds extra headers after edit
Display: Edit form, unable to enter text in display Player Version search field
Layout: Dataset preview not functioning in version 4.3
Layout: duration is incorrect in the XLF
Layout: Duration not uploading correct with Global Element/Image
Layout: Player apps do not display layout after it is unretired
Layout Editor: Font configuration inside a button is not followed accordingly
Library: Replace/Expire Media: Unable to delete expired media after replacement
Library: S3 thumbnail URLs should output a * CORS header
Reports: API Request History: Report shows incorrect/no data
Reports: Chart: Distribution by Layout, Media or Event, the Count is not showing correctly
Schedule: Error found when deleting a priority
Schedule Criteria: if Events are set to Repeat, they are added to the schedule on the display regardless of if criteria is true
Settings: Phone Home URL still shown in settings
UI: Switch ‘Youtube’ button to ‘Training’ button, and redirect, in floating help button
UI: Remove feedback form from white label CMS
UI: Add a hyperlink to report an issue
UI: Add Privacy Notice to the floating form
User Groups: search filter not working
Widget: Arrow tip/dot appears misplaced on Tizen
Widget: Currency reverse conversion not functioning correctly
Widget: DataSet widget cache appears to be expiring too quickly
Widget: Interactive button text not displaying on Tizen when “Fit to Selection” is enabled
XMDS: checking bandwidth uses lots of CPU
XMDS: improve logging when returning a HTTP file request
You can find the full release notes here along with the changelog here.
Download
Please use the links below to download this release:
Xibo for Apache/Nginx / WAMP/IIS
Visit our Downloads page for all the latest releases.
Install / Upgrade
Instructions for installation/upgrade can be found here.
The minimum version of PHP needed to run the CMS is PHP 8.1.
Please note: Xibo 4.3 does not require ZeroMQ/ZMQ dependencies for the web container, making it easier to install for those of you not using Docker. See the Apache/IIS notes for more information.
Feedback
Please let us know what you think of v4.3.1.
