We’re pleased to announce the latest CMS release, Xibo version 4.2.0! The codename for this version is “Kopff”.
This is a companion discussion topic for the original entry at https://xibosignage.com/blog/4-2-0-released
Thank you for the great Release. It is very fast and useful.
i miss something in the documentation. In Germany we get the CAP Feed in json Format. Maybe Xibo need it in XML. There is no validation or hint in the documentation. It doesn’t show anything ![]()
i tried:
https://warnung.bund.de/api31/mowas/mapData.json
https://www.dwd.de/DWD/warnungen/cap-feed/de/atom.xml
Excited to hear that ChromeOS support is coming!
6 posts were split to a new topic: MariaDB error on upgrade to 4.2.0 release
I’m running Windows/IIS and interestingly enough, XMR doesn’t start or run using the “new” config.json. I get no output at all when I run php xmr.phar.
If I copy the old one (
“listenOn”: “tcp://127.0.0.1:50001”,
“pubOn”: [“tcp://10.1.10.8:9505”, “tcp://10.1.10.8:50002”],
“debug”: true
it starts right up and runs fine. Any ideas on where to look or additional guidance? Would love to move away from relying on ZMQ given the trouble that has been lately.
Hi! @wer83
Check this topic:
6 posts were split to a new topic: Can’t install Xibo v4.2.0 on shared hosting
A post was split to a new topic: Sync playback - one device out of sync
I upgraded my cms server few minutes ago.
It looks fine.
Especially, I like text editor in this cms version. IT is awesome.
Thank you very much for your devotion!
Regards Lee
3 posts were split to a new topic: Display list empty after 4.1 → 4.2 upgrade
A post was split to a new topic: CMS 2.3.9 to 4.2.0 upgrade
2 posts were split to a new topic: Remote column setting issue
Did you find out how to implement the DWD feed into xibo? I’m thinking about just implementing the rss feed to somehow get it working.
Does anyone know how to import a cap feed like Official Warnings ?
