Installation Method
Docker
Operating System
Ubuntu 22.04
Xibo CMS stuck in off-line/upgrade mode when upgrading from 3.3.7 to 4.0.1
Related to the last line from logs cms-web, below? If so, I do I fix?
xibocms-cms-web-1 | We will upgrade it, take a backup
xibocms-cms-web-1 | mysqldump: Error: ‘Access denied; you need (at least one of) the PROCESS privilege(s) for this operation’ when trying to dump tablespaces
xibocms-cms-web-1 | Running database migrations
xibocms-cms-web-1 | Phinx by CakePHP - https://phinx.org.
xibocms-cms-web-1 |
xibocms-cms-web-1 | using config file /var/www/cms/phinx.php
xibocms-cms-web-1 | using config parser php
xibocms-cms-web-1 | using migration paths
xibocms-cms-web-1 | - /var/www/cms/db/migrations
xibocms-cms-web-1 | warning no environment specified, defaulting to: production
xibocms-cms-web-1 | using adapter mysql
xibocms-cms-web-1 | using database cms
xibocms-cms-web-1 | ordering by creation time
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220330111440 ModulesTableVerFourMigration: migrating
xibocms-cms-web-1 | == 20220330111440 ModulesTableVerFourMigration: migrated 0.1017s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220512130000 AddTwitterConnectorMigration: migrating
xibocms-cms-web-1 | == 20220512130000 AddTwitterConnectorMigration: migrated 0.0087s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220512155400 RegionTypeMigration: migrating
xibocms-cms-web-1 | == 20220512155400 RegionTypeMigration: migrated 0.0239s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220520175400 DisplayMediaMigration: migrating
xibocms-cms-web-1 | == 20220520175400 DisplayMediaMigration: migrated 0.1751s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220903153600 RequiredfileDependencyMigration: migrating
xibocms-cms-web-1 | == 20220903153600 RequiredfileDependencyMigration: migrated 0.1466s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220915100902 AddFontsTableMigration: migrating
xibocms-cms-web-1 | == 20220915100902 AddFontsTableMigration: migrated 0.1194s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20220928091249 PlayerSoftwareRefactorMigration: migrating
xibocms-cms-web-1 | == 20220928091249 PlayerSoftwareRefactorMigration: migrated 0.1264s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20221124120259 AddLayoutIdToActionTableMigration: migrating
xibocms-cms-web-1 | == 20221124120259 AddLayoutIdToActionTableMigration: migrated 0.0172s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230118151031 AddAlphaVantageConnectorMigration: migrating
xibocms-cms-web-1 | == 20230118151031 AddAlphaVantageConnectorMigration: migrated 0.0134s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230130114907 UpdateCampaignDisplayColumnDataTypeMigration: migrating
xibocms-cms-web-1 | == 20230130114907 UpdateCampaignDisplayColumnDataTypeMigration: migrated 0.3438s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230209132720 AddOpenWeatherMapConnectorMigration: migrating
xibocms-cms-web-1 | == 20230209132720 AddOpenWeatherMapConnectorMigration: migrated 0.0245s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230214135035 RemoveDoohUserTypeMigration: migrating
xibocms-cms-web-1 | == 20230214135035 RemoveDoohUserTypeMigration: migrated 0.1135s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230220213618 UpdatePlayListTimelineHelpLinkMigration: migrating
xibocms-cms-web-1 | == 20230220213618 UpdatePlayListTimelineHelpLinkMigration: migrated 0.0135s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230310143321 SavedReportMoveOutMigration: migrating
xibocms-cms-web-1 | == 20230310143321 SavedReportMoveOutMigration: migrated 0.1213s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230321105750 AddSchemaVersionWidgetMigration: migrating
xibocms-cms-web-1 | == 20230321105750 AddSchemaVersionWidgetMigration: migrated 0.0231s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230411090410 AddWidgetCompatibilityTaskMigration: migrating
xibocms-cms-web-1 | == 20230411090410 AddWidgetCompatibilityTaskMigration: migrated 0.0166s
xibocms-cms-web-1 |
xibocms-cms-web-1 | == 20230509113820 ContentSyncMigration: migrating
xibocms-cms-web-1 | PDOException: SQLSTATE[HY000]: General error: 1366 Incorrect string value: ‘\x80\x80navL…’ for column ‘actionType’ at row 1 in /var/www/cms/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php:192
