### CMS Version: 2.3.16
### Operating System: Ubuntu 18.04.5 LTS
### Installation: Docker
### Docker Version: 19.03.12
Hi community,
I need to migrate a CMS installation from an AWS instance to a local server. I’m having some problems since I have never done a fresh install of a Xibo server and have basic knowledge about Docker.
I’ve tried a few things like:
- Copying the whole
/opt/xibo
directory and trying docker-compose up -d
on the new server. It ran without errors, but I couldn’t access the CMS webserver.
- Doing a fresh install of Xibo CMS and replacing the
shared
directory. The new installation worked until I replaced the shared
directory.
One thing I noticed is that the old installation has an Apache2 service running on the host system, and I could only do a Xibo fresh install without Apache2 installed on the host.
I know my CMS version is very old, and I plan to upgrade it, but I want to do it after the migration, which I can perform in a testing environment.
I couldn’t find any information about this in any documentation or by looking through past topics here.
I thank you in advance for any help.
Hello @FranciscoAdeFaria
Welcome to the Xibo community forum.
Could you please post your new docker compose file content ?
Hi ProServ,
Sorry for the delay.
The new docker-compose file is the following:
version: “2.1”
services:
cms-db:
image: mysql:5.7
volumes:
- “./shared/db:/var/lib/mysql:Z”
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 1g
env_file: config.env
restart: always
cms-xmr:
image: xibosignage/xibo-xmr:release-0.8
ports:
- “9505:9505”
restart: always
mem_limit: 256m
cms-web:
image: xibosignage/xibo-cms:release-2.3.16
volumes:
- “./shared/cms/custom:/var/www/cms/custom:Z”
- “./shared/backup:/var/www/backup:Z”
- “./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z”
- “./shared/cms/library:/var/www/cms/library:Z”
- “./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z”
- “./shared/cms/ca-certs:/var/www/cms/ca-certs:Z”
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- “80:80”
mem_limit: 1g
cms-quickchart:
image: ianw/quickchart
restart: always
The docker compose of the running instance is:
version: “2.1”
services:
cms-db:
image: mysql:5.6
volumes:
restart: always
environment:
- MYSQL_USER=cms
mem_limit: 1g
cms-xmr:
ports:
- “9505:9505”
restart: always
mem_limit: 512m
cms-web:
volumes:
volumes:
- "./shared/cms/custom:/var/www/cms/custom:Z"
- "./shared/backup:/var/www/backup:Z"
- "./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z"
- "./shared/cms/library:/var/www/cms/library:Z"
- "./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z"
- "./shared/cms/ca-certs:/var/www/cms/ca-certs:Z"
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- "127.0.0.1:8080:80"
mem_limit: 2g
cms-quickchart:
restart: always
