Hi, please help, I get to this point and cannot proceed further with error “Bind for 0.0.0.0:8080 failed: port is already allocated”
Step 13/15 : EXPOSE 80
—> Using cache
—> fa53b427e4ae
Step 14/15 : RUN mkdir -p /var/www/cms && mkdir -p /var/www/cms/library/temp && mkdir -p /var/www/cms/cache && mkdir -p /var/www/backup
—> Using cache
—> d8d5294ac0ab
Step 15/15 : CMD ["/entrypoint.sh"]
—> Using cache
—> 9dbaa200329b
Successfully built 9dbaa200329b
Successfully tagged xibo-cms_web:latest
xibo-cms_xmr_1 is up-to-date
xibo-cms_db_1 is up-to-date
Starting xibo-cms_swagger_1 …
Starting xibo-cms_swagger_1 … error
ERROR: for xibo-cms_swagger_1 Cannot start service swagger: driver failed programming external connectivity on endpoint xibo-cms_swagger_1 (84d3d6e8fbccc6ca4155c340760c9c55e2602b600bed9969eb713d8061bce529): Error starting userland proxy: Bind for 0.0.0.0:8080 failed: port is already allocated
ERROR: for swagger Cannot start service swagger: driver failed programming external connectivity on endpoint xibo-cms_swagger_1 (84d3d6e8fbccc6ca4155c340760c9c55e2602b600bed9969eb713d8061bce529): Error starting userland proxy: Bind for 0.0.0.0:8080 failed: port is already allocated
ERROR: Encountered errors while bringing up the project.
