Xibo CMS 4.2.2 Released
We've been hard at work further refining the 4.2 version of our CMS.
This latest patch will fix over 26 issues, improving the user experience and enhancing stability and performance. The codename for this version is “Kopff”.
This is a companion discussion topic for the original entry at https://xibosignage.com/blog/4-2-2-released
I had problems upgrading from xibo 4.1.2 on ubuntu server 24.04 and Maria DB to xibo 4.2.1. The problem with version 4.2.2 has been solved, will I be able to upgrade the CMS?
Yes it is. Do a backup before, and then you can upgrade your CMS’s wihtout major problems :slight_smile:
Hi there,
I just upgraded and everything is working fine except my reboot commands. I think I need to set XMR differently than the previous version, am I right? Could you tell us more about the new XMR features and how to set it properly? Thanks in advance for your feedback.
