This is a companion discussion topic for the original entry at https://xibosignage.com/blog/4-0-7-released
As a user you can’t create folders under the home folder. It will look like it’s created but when you refresh the page it’s not there. If you login as admin you can see the folder but it only says New Folder.
Thank you,
John
I also noticed since v4 you can’t have a space when creating a user.
Example:
New User now has to be NewUser
Is this by design?
Thank you,
John
If one of the MenuBoard Slots has no animation effect, (see in the picture below the Price). All other information changing but the one without effect staying at the old value. (And changing random)
If i press shift in menu board layout to make a group, the elements are invisible. This is only at my menu board layout. At Dataset it is normal
If you replace a Picture at media, its not connected in a menuboard item anymore:
Would be cool to have “back” buttons in the dataset editor.
