We are pleased to announce the third patch to the 4.0 version of the Xibo CMS. The codename for this version is “Westphal”.
This is a companion discussion topic for the original entry at https://xibosignage.com/blog/4-0-3-released
I previously apologized if I asked on this topic…
I would like to ask, how to create 3 video files in 1 region and 3 music files in 1 region (where this region is different from the region for videos) on one same layout in xibo version 4.0.3?
For example you can see the picture below:
I used xibo version 3.3.8 for the image above and I put a red box mark for 3 video files and 3 music files that I mentioned above.
Maybe someone in this forum (Mr. @dan or Mrs. @natasha or Mr. @pitoco02 ) can help…
Best regards,
Ray
Hi @NewBie_1
That’s the way i did:
2 playlists widgets:
basically EVERYTHING that you did with Regions, you can do using the Playlists widget:
Hello Mr. Pitoco02,
Thanks for your help, your instructions are very correct. Once again thank you so much and God Bless You
Best regards,
Ray
