Xibo CMS 3.2.0
PHP 7.4
I did the installation of the new version of XIBO 3.2.0 but it presented an error during the installation. I uploaded and unzipped without any problems. I started the process of checking the extensions and they are all ok. I went ahead to configure the Mysql data and then when I should go to the screen to create the administrator user and a password I return this error:
Slim Application Error
The application could not run because of the following error:
Details
Type: Xibo\Support\Exception\InstallationError
Code: 0
Message: CMS is already installed. Please contact the server administrator.
File: /www/wwwroot/app.pontods.com.br/lib/routes-install.php
Line: 85
trace
#0 [internal function]: {closure}()
#1 /www/wwwroot/app.pontods.com.br/vendor/php-di/invoker/src/Invoker.php(82): call_user_func_array()
#2 /www/wwwroot/app.pontods.com.br/vendor/php-di/slim-bridge/src/ControllerInvoker.php(47): Invoker\Invoker->call()
#3 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/Routing/Route.php(384): DI\Bridge\Slim\ControllerInvoker->__invoke()
#4 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\Routing\Route->handle()
#5 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): Slim\MiddlewareDispatcher->handle()
#6 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/Routing/Route.php(341): Slim\MiddlewareDispatcher->handle()
#7 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/Routing/RouteRunner.php(84): Slim\Routing\Route->run()
#8 /www/wwwroot/app.pontods.com.br/vendor/slim/twig-view/src/TwigMiddleware.php(125): Slim\Routing\RouteRunner->handle()
#9 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Views\TwigMiddleware->process()
#10 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php(59): class@anonymous->handle()
#11 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\RoutingMiddleware->process()
#12 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(107): class@anonymous->handle()
#13 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/MiddlewareDispatcher.php(147): Slim\Middleware\ErrorMiddleware->process()
#14 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/MiddlewareDispatcher.php(81): class@anonymous->handle()
#15 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/App.php(215): Slim\MiddlewareDispatcher->handle()
#16 /www/wwwroot/app.pontods.com.br/vendor/slim/slim/Slim/App.php(199): Slim\App->handle()
#17 /www/wwwroot/app.pontods.com.br/web/install/index.php(101): Slim\App->run()
#18 {main}
It was about 20 seconds loading without success on this Database configuration screen and then immediately presented the error message mentioned above
