system
September 8, 2021, 12:17pm
1
We are pleased to announce our 3rd patch for the 3.0 version of Xibo. The codename for this version is “Finlay”. Check out our release announcement and our What’s New in Xibo v3 blogs for more details about the updated features.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/3-0-3-released/
davede
September 21, 2021, 10:49am
2
Do I need to update my 3.0 to 3.0.1, and so on or can I just update it directly to the 3.0.3?
natasha
September 22, 2021, 11:20am
3
You can directly upgrade to v3.0.3 from v3.0
Hello Natasha,
For an upgrade from 3.0.1 to 3.0.3 on white brand docker installation, what do you suggest ?
Best regards,
I can see that you have opened a ticket with our help desk who will work with you on this
Thank you
Does anyone have a direct link to the docs for going from 2.3.x to 3.0.x ?
The CMS can be upgraded from a 2.x to a 3.x using the installation instructions appropriate for your installation using the link: Upgrading the CMS | Xibo Open Source Digital Signage
