Xibo CMS 2.3.3
Installation Method
Custom install
Operating System
Windows Server 2008 R2 Standard
It is not possible to edit a repeated event.
Provide screenshots where possible!
Xibo CMS 2.3.3
Custom install
Thank you for your message hhan. I have created a repeating event in my test 2.3.3 CMS but I have been able to edit it without issue. Please confirm the following:
Can you also provide some troubleshoot logs so I can see what the error is? To create the logs:
Report Fault
option in your CMS.Turn on Debugging
when the option is available.Open in a new Window
and try to edit your Event in that new tab.Report Fault
tab.Collect and Save
to create the troubleshoot logs.Turn off Debugging
when the option appears.You may wish to send the logs in a private message to avoid posting sensitive information publicly on the Forum.
can the problem be the php version (PHP 7.0.8 (VC14 X86 32bit thread safe) + PEAR)?
It is due to the 32 bit php version. I tried it with 64 bit php version and it worked.
Unfortunately I can not use the 64bit php version because then ZeroMQ push communication crashes the Apache when requesting a ScreenShot.
