Xibo browser in not supported
Hi
I have a problem using a webpage widget is not working, After running the client There was a message showing that “Your browser in not fully supported, please try newer version”
1.Links used from Grafana
2.Xibo player from Window 10
3.Xibo version.1.8 (Self hosted)
4.Browser used Microsoft Edge
You’ll need to upgrade to take advantage of newer browser technologies in the player. Xibo 1.8 is really old, hence the older browser.
Xibo v4 uses Chrome 126 or the Chrome based Edge, at your preference.
