Xibo Authentication with Entra ID
Hello
I want my xibo account use AD authentification, I follow the guide below :SAML Single Sign on with Active Directory - ADFS | Xibo Digital Signage
but I didn’t use adfs server I use entra ID
but not worked for me , any one know if xibo work with entra ID
thanks
its not that hard, but it needs some attention… and not all settings are the same for everyone
I was able to make it using those topics bellow:
hi thanks for your answer,
I did the same configuration but was not worked for us, it’s very weird ,
it’s look like the file settings-custom.php not impacted or used by xibo because when we edit this file nothing change
You may use only settings.php to do this…
put those configs inside “settings.php” file, and will work
where I can find the setting.php for xibo ?
in the same path:
Settings.php is the same file that you insert you databse connection.
But you will also insert the config from SAML
/web folder
thanks a lot I fix it now
but I had an issue now that is show this below error message :
Error - AADSTS75011 Authentication method by which the user authenticated with the service doesn’t match requested authentication method AuthnContextClassRef
I changed the value from false to true on ‘authnRequestsSigned’ but I have this an other issue
Error
Unexpected Error, please contact support.
I don’t know is still any other setting I need to do it
thanks
this is the config from xibo side
This is how i use mine:
And the custom attributes from entra i set like this:
Delete all custom attibuttes, and the two you need to use is:
mail
uid
In my case i use the user mail to identify the user inside the cms, this why both of declarations are set usign “user.mail” as value to the attibute. But that is not a rule.
The rule is that you need to declare those attibutes and the value can be customized basing in how you will login into your CMS.
and inside the settings.php i use those declaration as you can see in the screenshot:
 'field_to_identify' => 'email',
and
'NameIDFormat' => 'urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress',
To me, it’s all working good.
thanks a lot pitoco02 is worked for me the only change I did after make the same config you have is to change from ‘field_to_identify’ => ‘email’, to ‘field_to_identify’ => ‘UserName’,
but I have question how I can give my AD account to be admin on XIBO ?
I’m glad to hear that! You can mark my awnser as “Solution”. It turns easier to other members with the same problem find this solution as well.
Yes, for users already created you can change do that in your database you set “userTypeId” as “1” in user table.
Or to create new users as superAdmin, Group Admin or User in your SAML config just set the configurations that you want in your settings.php file:
can be 1, 2 or 3.
yes thank a lot is worked for me, you are the best thanks a lot
