Hi
We want to understand architecture of Xibo signage player with soap apis documentation(for java),
Where can we get the detailed specification documents and developer documentation?
Have a nice day.
Best regards,
Hi
Have a nice day.
Best regards,
There is some API documentation online. SOAP and WSDL allows you to auto-generate the code you need for your API. You can use wsdl2java - takes a WSDL document and generates fully annotated Java code from which to implement a service.
The Player API is described here: http://xibo.org.uk/manual-tempel/en/xmds.html
Link http://xibo.org.uk/manual-tempel/en/xmds.html 404 not found.
This topic is from 7 years ago!
Iād suggest you start your journey by looking at our developer documentation: Introduction | Xibo Digital Signage
