JRD
September 27, 2023, 10:31am
1
4.0.2 to 4.0.3
Installation Method
Custom install IIS/Windows
Operating System
Windows 2019
After completing the below steps to upgrade my xibo installation I get the CMS is Tempory off-line to perform maintenance. What have I missed??
Steps taken to perform upgrade.
Stop the website
Rename the folder
D:\WebSites\SHRXibo\xibo to D:\WebSites\SHRXibo\xibo_old [version ]
Extract the zip file to the destination folder
Paste the setting.php file from D:\WebSites\SHRXibo\xibo_old [version ]\web
to D:\WebSites\SHRXibo\xibo\web\settings.php
Run the migration update code (administrator command prompt)
php vendor/bin/phinx migrate -c phinx.php –Completed OK
Set permissions on Cache folder.
Start the web server.
Add the URL rewrite rules
Did you still have your "web.config"
file in the /web
folder?
JRD
September 28, 2023, 10:07am
3
Just carried it out again restoring from backup before hand, and have the same result, the web.conf file is in the web folder.
I think that the problem is in the web.config
file… Can you send here how your file is setted?
JRD
October 2, 2023, 12:21pm
5
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
<system.webServer>
<rewrite>
<rules>
<rule name="Imported Rule 1" stopProcessing="true">
<match url="^" ignoreCase="false" />
<conditions logicalGrouping="MatchAll">
<add input="{HTTP_AUTHORIZATION}" pattern=".+" ignoreCase="false" />
<add input="{REQUEST_FILENAME}" matchType="IsFile" ignoreCase="false" negate="true" />
<add input="{URL}" pattern="^/api/authorize/.*$" ignoreCase="false" />
</conditions>
<action type="Rewrite" url="api/authorize/index.php" appendQueryString="true" />
</rule>
<rule name="Imported Rule 2" stopProcessing="true">
<add input="{URL}" pattern="^/api/.*$" ignoreCase="false" />
</conditions>
<action type="Rewrite" url="api/index.php" appendQueryString="true" />
</rule>
<rule name="Imported Rule 3" stopProcessing="true">
<add input="{URL}" pattern="^/install/.*$" ignoreCase="false" />
</conditions>
<action type="Rewrite" url="install/index.php" appendQueryString="true" />
</rule>
<rule name="Imported Rule 4" stopProcessing="true">
<add input="{REQUEST_FILENAME}" matchType="IsDirectory" ignoreCase="false" negate="true" />
<add input="{REQUEST_FILENAME}" pattern="\.(css|js|png|jpg)$" ignoreCase="false" negate="true" />
<add input="{URL}" pattern="^/dist/.*$" ignoreCase="false" negate="true" />
<add input="{URL}" pattern="^/theme/.*$" ignoreCase="false" negate="true" />
</conditions>
<action type="Rewrite" url="index.php" appendQueryString="true" />
</rule>
</rules>
</rewrite>
</system.webServer>
<system.web>
<identity impersonate="false" />
</system.web>
</configuration>
Can you run the phinx again?
JRD
October 2, 2023, 12:49pm
8
It runs fine doesn’t error
dan
October 2, 2023, 8:02pm
9
Please can you post a screenshot of the exact message you’re seeing, just so we can be sure we’re looking in the right place?
JRD
October 3, 2023, 8:13am
10
Folders: d:\Websites\xibo
IIS Folder path: d:\websites\xibo\web
Stopped IIS
Renamed Xibo folder xibo_old
Renamed Xibo 4.0.3 to Xibo
copied settings.php and web.config from xibo_old\web to xibo\web
started IIS
Ran migration php script
> D:\WebSites\xibo>php vendor/bin/phinx migrate -c phinx.php
> Phinx by CakePHP - https://phinx.org.
> using config file phinx.php
> using config parser php
> using migration paths
> - D:\WebSites\xibo\db\migrations
> warning no environment specified, defaulting to: production
> using adapter mysql
> using database xibodb
> ordering by creation time
> All Done. Took 5.8569s
D:\WebSites\xibo>
(Screen copy of results of command)
started IIS
Set permission on Cache folder for IIS_IUSRS to full
When browsing to the Xibo managment console I get
The CMS is temporarily off-line as an upgrade is in progress. Please check with your system administrator for updates or refresh your page in a few minutes.
dan
October 3, 2023, 1:00pm
11
It looks like no migrations have been found. What do you get as the output of the status command?
php vendor/bin/phinx status
JRD
October 3, 2023, 1:37pm
12
Quite a lot text…last line look relevant
Status [Migration ID] Started Finished Migration Name
up 20180130073838 2023-09-15 07:29:49 2023-09-15 07:29:51 InstallMigration
up 20180131113100 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep85Migration
up 20180131113853 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep86Migration
up 20180131113941 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep87Migration
up 20180131113948 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep88Migration
up 20180131113952 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep92Migration
up 20180131113957 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep120Migration
up 20180131114002 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep121Migration
up 20180131114007 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep122Migration
up 20180131114013 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep123Migration
up 20180131114017 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep124Migration
up 20180131114021 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep125Migration
up 20180131114025 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep126Migration
up 20180131114030 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep127Migration
up 20180131114050 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep128Migration
up 20180131114058 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep129Migration
up 20180131114103 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep130Migration
up 20180131114107 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep131Migration
up 20180131114110 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep132Migration
up 20180131114114 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep133Migration
up 20180131114118 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep134Migration
up 20180131114123 2023-09-15 07:29:51 2023-09-15 07:29:51 OldUpgradeStep135Migration
up 20180131122645 2023-09-15 07:29:51 2023-09-15 07:29:51 OneRegionPerPlaylistMigration
up 20180131123038 2023-09-15 07:29:51 2023-09-15 07:29:51 PlaylistTagsMigration
up 20180131123248 2023-09-15 07:29:51 2023-09-15 07:29:51 WidgetFromToDtMigration
up 20180212143336 2023-09-15 07:29:51 2023-09-15 07:29:51 DaypartSystemEntriesAsRecords
up 20180213173846 2023-09-15 07:29:51 2023-09-15 07:29:51 MailFromNameSettingMigration
up 20180219141257 2023-09-15 07:29:51 2023-09-15 07:29:51 DisplayGroupClosureIndexToNonUnique
up 20180223180534 2023-09-15 07:29:51 2023-09-15 07:29:51 DataSetColumnFilterAndSortOptionsMigration
up 20180302182421 2023-09-15 07:29:51 2023-09-15 07:29:51 WidgetCreatedAndModifiedDtMigration
up 20180313085749 2023-09-15 07:29:51 2023-09-15 07:29:51 MediaTableEditedIdIndexMigration
up 20180320154652 2023-09-15 07:29:51 2023-09-15 07:29:51 PlaylistAddDynamicFilterMigration
up 20180327153325 2023-09-15 07:29:51 2023-09-15 07:29:51 RemoveUserLoggedInMigration
up 20180514114415 2023-09-15 07:29:51 2023-09-15 07:29:51 FixCaseOnHelpTextFieldMigration
up 20180515123835 2023-09-15 07:29:51 2023-09-15 07:29:51 LayoutPublishDraftMigration
up 20180529065816 2023-09-15 07:29:51 2023-09-15 07:29:51 DataSetTruncateFixMigration
up 20180529073531 2023-09-15 07:29:51 2023-09-15 07:29:51 DisplayAsVncLinkMigration
up 20180621134013 2023-09-15 07:29:51 2023-09-15 07:29:51 AddWidgetSyncTaskMigration
up 20180621134250 2023-09-15 07:29:51 2023-09-15 07:29:51 EventLayoutPermissionSettingMigration
up 20180906115552 2023-09-15 07:29:51 2023-09-15 07:29:51 AddForeignKeysToTagsMigration
up 20180906115606 2023-09-15 07:29:51 2023-09-15 07:29:51 AddForeignKeysToPermissionsMigration
up 20180906115712 2023-09-15 07:29:51 2023-09-15 07:29:51 AddForeignKeysToWidgetMediaMigration
up 20180906131643 2023-09-15 07:29:51 2023-09-15 07:29:51 ForgottenPasswordReminderMigration
up 20180906131716 2023-09-15 07:29:51 2023-09-15 07:29:51 DataSetRssMigration
up 20181011160130 2023-09-15 07:29:51 2023-09-15 07:29:51 SimpleSettingsMigration
up 20181113173310 2023-09-15 07:29:51 2023-09-15 07:29:51 RemoveFinanceModuleMigration
up 20181113180337 2023-09-15 07:29:51 2023-09-15 07:29:51 SplitTickerModuleMigration
up 20181126113231 2023-09-15 07:29:51 2023-09-15 07:29:51 Release1812Migration
up 20181210092443 2023-09-15 07:29:51 2023-09-15 07:29:51 RemoveImageUriModuleMigration
up 20181212114400 2023-09-15 07:29:51 2023-09-15 07:29:51 CreatePlayerVersionsTableMigration
up 20181217135044 2023-09-15 07:29:51 2023-09-15 07:29:51 EventSyncMigration
up 20190121092556 2023-09-15 07:29:51 2023-09-15 07:29:51 PlayerUpgradeAndOverrideConfigMigration
up 20190125170130 2023-09-15 07:29:51 2023-09-15 07:29:51 PlayerSoftwareVersionFieldMigration
up 20190129103831 2023-09-15 07:29:51 2023-09-15 07:29:51 AddLinuxDisplayProfileMigration
up 20190212112534 2023-09-15 07:29:51 2023-09-15 07:29:51 AddProofOfPlayStatsDurationAndCountMigration
up 20190212115432 2023-09-15 07:29:51 2023-09-15 07:29:51 AddDefaultTransitionDurationSettingMigration
up 20190213160914 2023-09-15 07:29:51 2023-09-15 07:29:51 AddGlobalStatSettingMigration
up 20190213162212 2023-09-15 07:29:51 2023-09-15 07:29:51 AddHorizontalMenuSettingMigration
up 20190214102508 2023-09-15 07:29:51 2023-09-15 07:29:51 AddLayoutEnableStat
up 20190214102516 2023-09-15 07:29:51 2023-09-15 07:29:51 AddMediaEnableStat
up 20190220165703 2023-09-15 07:29:51 2023-09-15 07:29:51 AddScheduleRecurrenceMonthlyRepeatsOnMigration
up 20190227101705 2023-09-15 07:29:51 2023-09-15 07:29:52 MakeDisplayLicenseColumnUniqueMigration
up 20190228120603 2023-09-15 07:29:52 2023-09-15 07:29:52 AddDynamicCriteriaTagsMigration
up 20190301115046 2023-09-15 07:29:52 2023-09-15 07:29:52 AdjustGenericfileValidExtensionsMigration
up 20190315134628 2023-09-15 07:29:52 2023-09-15 07:29:52 AddBandwidthLimitColumnToDisplaygroupMigration
up 20190322162052 2023-09-15 07:29:52 2023-09-15 07:29:52 AddPublishedDateColumnMigration
up 20190326163016 2023-09-15 07:29:52 2023-09-15 07:29:52 CreateLayoutHistoryTableMigration
up 20190328111718 2023-09-15 07:29:52 2023-09-15 07:29:52 AddCampaignStatMigration
up 20190401150256 2023-09-15 07:29:52 2023-09-15 07:29:52 AddScheduleNowPageMigration
up 20190509101525 2023-09-15 07:29:52 2023-09-15 07:29:52 CreateReportScheduleTableMigration
up 20190509102648 2023-09-15 07:29:52 2023-09-15 07:29:52 CreateSavedReportTableMigration
up 20190509113001 2023-09-15 07:29:52 2023-09-15 07:29:52 AddReportPageMigration
up 20190510140126 2023-09-15 07:29:52 2023-09-15 07:29:52 TwoFactorAuthMigration
up 20190514134430 2023-09-15 07:29:52 2023-09-15 07:29:52 NullableTextFieldsMigration
up 20190515094133 2023-09-15 07:29:52 2023-09-15 07:29:52 AddHtmlDatatypeMigration
up 20190515105624 2023-09-15 07:29:52 2023-09-15 07:29:52 InstallAdditionalStandardModulesMigration
up 20190517080033 2023-09-15 07:29:52 2023-09-15 07:29:52 AddForeignKeysToLktagTablesMigration
up 20190521092700 2023-09-15 07:29:52 2023-09-15 07:29:52 AddReportScheduleTaskMigration
up 20190521092930 2023-09-15 07:29:52 2023-09-15 07:29:52 AddPreviousRunDateReportScheduleMigration
up 20190521102635 2023-09-15 07:29:52 2023-09-15 07:29:52 PlaylistDurationUpdateAtTimestamp
up 20190603083836 2023-09-15 07:29:52 2023-09-15 07:29:52 ChangeStatTableStartEndColumnMigration
up 20190610150331 2023-09-15 07:29:52 2023-09-15 07:29:52 TagsWithValuesMigration
up 20190611145607 2023-09-15 07:29:52 2023-09-15 07:29:52 RemoveOldVersionTableMigration
up 20190612140955 2023-09-15 07:29:52 2023-09-15 07:29:52 DisplayTableDatabaseSchemaAdjustmentsMigration
up 20190620112611 2023-09-15 07:29:52 2023-09-15 07:29:52 MoveTidyStatsToStatsArchiveTaskMigration
up 20190620142655 2023-09-15 07:29:52 2023-09-15 07:29:52 AddPlaylistEnableStatMigration
up 20190626091331 2023-09-15 07:29:52 2023-09-15 07:29:52 WidgetHistoryMigration
up 20190626110359 2023-09-15 07:29:52 2023-09-15 07:29:52 CreateStatTableMigration
up 20190628083649 2023-09-15 07:29:52 2023-09-15 07:29:52 AddStatsMigrationTaskMigration
up 20190710213414 2023-09-15 07:29:52 2023-09-15 07:29:52 AddIsActiveReportScheduleMigration
up 20190717101342 2023-09-15 07:29:52 2023-09-15 07:29:52 NullableCommandValidationStringMigration
up 20190719074601 2023-09-15 07:29:52 2023-09-15 07:29:52 MissingDefaultValueMigration
up 20190725115532 2023-09-15 07:29:52 2023-09-15 07:29:52 AddScheduleReminderTaskMigration
up 20190801102042 2023-09-15 07:29:52 2023-09-15 07:29:52 DisplayProfileCommandLinkFixMigration
up 20190801141737 2023-09-15 07:29:52 2023-09-15 07:29:52 DatasetAddCustomHeadersColumnMigration
up 20190801142302 2023-09-15 07:29:52 2023-09-15 07:29:52 AddDoohUserTypeMigration
up 20190802145636 2023-09-15 07:29:52 2023-09-15 07:29:52 CreateScheduleReminderTableMigration
up 20190806144729 2023-09-15 07:29:52 2023-09-15 07:29:52 AddShowContentFromMigration
up 20190823081448 2023-09-15 07:29:52 2023-09-15 07:29:52 AddImageProcessingTaskMigration
up 20190828123735 2023-09-15 07:29:52 2023-09-15 07:29:52 AddDefaultSettingResizeLimitResizeThresholdMigration
up 20190903083314 2023-09-15 07:29:52 2023-09-15 07:29:52 AddGlobalSettingForCascadePermissionsMigration
up 20190905084201 2023-09-15 07:29:52 2023-09-15 07:29:52 AddSettingForDefaultTransitionTypeMigration
up 20190905084642 2023-09-15 07:29:52 2023-09-15 07:29:52 AddSettingForAutoLayoutPublishMigration
up 20190910132520 2023-09-15 07:29:52 2023-09-15 07:29:52 DisplayMoveCmsMigration
up 20190917093141 2023-09-15 07:29:52 2023-09-15 07:29:52 InterruptLayoutMigration
up 20190918090608 2023-09-15 07:29:52 2023-09-15 07:29:52 AddDefaultSettingQuickChartMigration
up 20190919154513 2023-09-15 07:29:52 2023-09-15 07:29:52 AddNotificationAttachmentFilenameNonUsersMigration
up 20190926135518 2023-09-15 07:29:52 2023-09-15 07:29:52 AddSettingForTransitionAutoApplyToLayoutMigration
up 20190926140809 2023-09-15 07:29:52 2023-09-15 07:29:52 InstallSavedReportsAndSpacerModulesMigration
up 20191001092651 2023-09-15 07:29:52 2023-09-15 07:29:52 AddNotificationOriginalFilenameMigration
up 20191022101141 2023-09-15 07:29:52 2023-09-15 07:29:52 AddCommandEntityToPermissionEntityMigration
up 20191024152519 2023-09-15 07:29:52 2023-09-15 07:29:52 AddScheduleExclusionsTableMigration
up 20191122114104 2023-09-15 07:29:52 2023-09-15 07:29:52 FixDuplicateModuleFilesMigration
up 20191126103120 2023-09-15 07:29:52 2023-09-15 07:29:53 GeoScheduleMigration
up 20191126141140 2023-09-15 07:29:53 2023-09-15 07:29:53 RemoteDataSetCsvSourceMigration
up 20191205180116 2023-09-15 07:29:53 2023-09-15 07:29:53 AddPlaylistDashboardPageUserMigration
up 20200107082625 2023-09-15 07:29:53 2023-09-15 07:29:53 DisplayAddResolutionMigration
up 20200115115935 2023-09-15 07:29:53 2023-09-15 07:29:53 AddReportScheduleMessageMigration
up 20200122143630 2023-09-15 07:29:53 2023-09-15 07:29:53 AddReleasedRequiredFileMigration
up 20200122191232 2023-09-15 07:29:53 2023-09-15 07:29:53 AddCommercialLicenceColumnMigration
up 20200129104944 2023-09-15 07:29:53 2023-09-15 07:29:53 AddEngagementsStatsMigration
up 20200130165443 2023-09-15 07:29:53 2023-09-15 07:29:53 CountdownModuleAddMigration
up 20200311110512 2023-09-15 07:29:53 2023-09-15 07:29:53 AddIsDrawerColumnMigration
up 20200311110535 2023-09-15 07:29:53 2023-09-15 07:29:53 CreateActionTableMigration
up 20200319093235 2023-09-15 07:29:53 2023-09-15 07:29:53 ChangeInterruptLayoutMigration
up 20200401121544 2023-09-15 07:29:53 2023-09-15 07:29:53 AddSystemUserSettingMigration
up 20200407143200 2023-09-15 07:29:53 2023-09-15 07:29:53 AddCodeColumnToLayoutMigration
up 20200422101006 2023-09-15 07:29:53 2023-09-15 07:29:53 AddDataSetRowLimitMigration
up 20200427085958 2023-09-15 07:29:53 2023-09-15 07:29:53 AddReportScheduleStartEndMigration
up 20200530103029 2023-09-15 07:29:53 2023-09-15 07:29:53 DisplayRemoteLinksMigration
up 20200604103141 2023-09-15 07:29:53 2023-09-15 07:29:53 CommandImprovementsMigration
up 20200612141755 2023-09-15 07:29:53 2023-09-15 07:29:53 OauthUpgradeMigration
up 20200720092246 2023-09-15 07:29:53 2023-09-15 07:29:53 AddSavedReportSchemaVersionMigration
up 20200916134817 2023-09-15 07:29:53 2023-09-15 07:29:53 RemoveOldScreenshotsMigration
up 20200917140227 2023-09-15 07:29:53 2023-09-15 07:29:53 DisplayGroupCreatedModifiedDates
up 20201007080829 2023-09-15 07:29:53 2023-09-15 07:29:53 AddFoldersMigration
up 20201007093511 2023-09-15 07:29:53 2023-09-15 07:29:53 FeaturesMigration
up 20201025153753 2023-09-15 07:29:53 2023-09-15 07:29:53 RemoveOldPermissionSettingsMigration
up 20210105105646 2023-09-15 07:29:53 2023-09-15 07:29:53 AddMcaasScopeAndRouteMigration
up 20210113134628 2023-09-15 07:29:53 2023-09-15 07:29:53 EnableUserSharingFeatureOnUsersGroupMigration
up 20210128143602 2023-09-15 07:29:53 2023-09-15 07:29:53 MenuBoardsMigration
up 20210201150259 2023-09-15 07:29:53 2023-09-15 07:29:53 UserOnboardingMigration
up 20210305131937 2023-09-15 07:29:53 2023-09-15 07:29:53 FixDuplicateTagsMigration
up 20210407111756 2023-09-15 07:29:53 2023-09-15 07:29:53 RemoveReportNameColumnFromSavedReportMigration
up 20210421142731 2023-09-15 07:29:53 2023-09-15 07:29:53 RemoveMaintenanceKeyMigration
up 20210601104441 2023-09-15 07:29:53 2023-09-15 07:29:53 AddUserAgentToDataSetMigration
up 20210603114231 2023-09-15 07:29:53 2023-09-15 07:29:53 NewCalendarTypeMigration
up 20210608142925 2023-09-15 07:29:53 2023-09-15 07:29:54 AddOrientationToResolutionAndMediaMigration
up 20210611122809 2023-09-15 07:29:54 2023-09-15 07:29:54 AddPurgeListTableMigration
up 20210806122814 2023-09-15 07:29:54 2023-09-15 07:29:54 AddNumberOfItemsToPlaylistMigration
up 20210813094723 2023-09-15 07:29:54 2023-09-15 07:29:54 AddCycleBasedPlaybackOptionToCampaignMigration
up 20210817105702 2023-09-15 07:29:54 2023-09-15 07:29:54 AddCustomSeparatorToDatasetMigration
up 20210820100520 2023-09-15 07:29:54 2023-09-15 07:29:54 AddActionEventTypeMigration
up 20210901134913 2023-09-15 07:29:54 2023-09-15 07:29:54 AddIpAddressColumnToAuditLogMigration
up 20210901150615 2023-09-15 07:29:54 2023-09-15 07:29:54 AddTooltipAndIsRequiredColumnsMigration
up 20211109130951 2023-09-15 07:29:54 2023-09-15 07:29:54 FixOrphanedDisplayGroupsMigration
up 20211109134929 2023-09-15 07:29:54 2023-09-15 07:29:54 FixPlaylistManagerUserGroupMigration
up 20211109141925 2023-09-15 07:29:54 2023-09-15 07:29:54 DatasetAddOptionToTruncateOnNoNewDataMigration
up 20211116153103 2023-09-15 07:29:54 2023-09-15 07:29:54 ConnectorsMigration
up 20211231141457 2023-09-15 07:29:54 2023-09-15 07:29:54 AddMoreTagFilteringOptionsMigration
up 20211231153355 2023-09-15 07:29:54 2023-09-15 07:29:54 AddIsCustomToDisplayProfileMigration
up 20220117150212 2023-09-15 07:29:54 2023-09-15 07:29:54 AddLayoutExchangeConnectorMigration
up 20220119124436 2023-09-15 07:29:54 2023-09-15 07:29:54 AddCodeColumnToMenuBoardsMigration
up 20220131151346 2023-09-15 07:29:54 2023-09-15 07:29:54 AddDateFormatToDataSetColumnMigration
up 20220201163832 2023-09-15 07:29:54 2023-09-15 07:29:54 ReportLogoMigration
up 20220203145712 2023-09-15 07:29:54 2023-09-15 07:29:54 ApplicationsTweaksMigration
up 20220207160047 2023-09-15 07:29:54 2023-09-15 07:29:54 TidyCalendarModuleTypes
up 20220224130122 2023-09-15 07:29:54 2023-09-15 07:29:54 AddResolutionRoutesToDesignScopeMigration
up 20220225105237 2023-09-15 07:29:54 2023-09-15 07:29:54 MergeWeatherWidgets
up 20220302152503 2023-09-15 07:29:54 2023-09-15 07:29:54 LayoutRemoveOrientationMigration
up 20220307134554 2023-09-15 07:29:54 2023-09-15 07:29:54 AddWorldClockMigration
up 20220330111440 2023-09-15 07:29:54 2023-09-15 07:29:54 ModulesTableVerFourMigration
up 20220512130000 2023-09-15 07:29:54 2023-09-15 07:29:54 AddTwitterConnectorMigration
up 20220512155400 2023-09-15 07:29:54 2023-09-15 07:29:54 RegionTypeMigration
up 20220520175400 2023-09-15 07:29:54 2023-09-15 07:29:54 DisplayMediaMigration
up 20220903153600 2023-09-15 07:29:54 2023-09-15 07:29:54 RequiredfileDependencyMigration
up 20220906085300 2023-09-15 07:29:54 2023-09-15 07:29:54 ThreeTwoZeroMigration
up 20220907135653 2023-09-15 07:29:54 2023-09-15 07:29:54 AddLogicalOperatorNameMigration
up 20220907143500 2023-09-15 07:29:54 2023-09-15 07:29:54 UserHomeFolderMigration
up 20220915100902 2023-09-15 07:29:54 2023-09-15 07:29:54 AddFontsTableMigration
up 20220928091249 2023-09-15 07:29:54 2023-09-15 07:29:54 PlayerSoftwareRefactorMigration
up 20221013103000 2023-09-15 07:29:54 2023-09-15 07:29:54 AdvertisingConnectorsMigration
up 20221024082400 2023-09-15 07:29:54 2023-09-15 07:29:54 AdCampaignMigration
up 20221101090337 2023-09-15 07:29:54 2023-09-15 07:29:54 CreateDisplayTypeTableMigration
up 20221101130018 2023-09-15 07:29:54 2023-09-15 07:29:54 AddDisplayMetaDataMigration
up 20221104095722 2023-09-15 07:29:54 2023-09-15 07:29:54 CreateDisplayLocationTypeTableMigration
up 20221124120259 2023-09-15 07:29:54 2023-09-15 07:29:54 AddLayoutIdToActionTableMigration
up 20230118151031 2023-09-15 07:29:54 2023-09-15 07:29:54 AddAlphaVantageConnectorMigration
up 20230130114907 2023-09-15 07:29:54 2023-09-15 07:29:54 UpdateCampaignDisplayColumnDataTypeMigration
up 20230209132720 2023-09-15 07:29:54 2023-09-15 07:29:54 AddOpenWeatherMapConnectorMigration
up 20230214135035 2023-09-15 07:29:54 2023-09-15 07:29:55 RemoveDoohUserTypeMigration
up 20230220213618 2023-09-15 07:29:55 2023-09-15 07:29:55 UpdatePlayListTimelineHelpLinkMigration
up 20230310143321 2023-09-15 07:29:55 2023-09-15 07:29:55 SavedReportMoveOutMigration
up 20230321105750 2023-09-15 07:29:55 2023-09-15 07:29:55 AddSchemaVersionWidgetMigration
up 20230411090410 2023-09-15 07:29:55 2023-09-15 07:29:55 AddWidgetCompatibilityTaskMigration
up 20230509113820 2023-09-15 07:29:55 2023-09-15 07:29:55 ContentSyncMigration
up 20230530124400 2023-09-15 07:29:55 2023-09-15 07:29:55 WidgetOptionSizeMigration
up 20230706103000 2023-09-15 07:29:55 2023-09-15 07:29:55 AddSyncKeyToZoneMigration
up 20230718163600 2023-09-15 07:29:55 2023-09-15 07:29:55 RemoveHelpLinksMigration
up 20230719154200 2023-09-15 07:29:55 2023-09-15 07:29:56 CollationToUtfmb4Migration
up 20230725141000 2023-09-15 07:29:56 2023-09-15 07:29:56 ScheduleMetaDataMigration
up 20230727102500 2023-09-15 07:29:56 2023-09-15 07:29:56 MenuboardAdditionalFieldsMigration
up 20230731194700 2023-09-15 07:29:56 2023-09-15 07:29:56 LkdgdgPrimaryKeyMigration
up 20230914133952 2023-09-15 07:29:56 2023-09-15 07:29:56 V20230914133952
** MISSING MIGRATION FILE **
JRD
October 5, 2023, 7:04am
13
Any updates, I’ll need to roll back to my backup soon.
Try to download again the files, and migrate again.
JRD
October 6, 2023, 7:35am
15
Done. exactly the same results.
JRD
October 9, 2023, 10:25am
16
Had to roll back to backup of the server.
dan
October 9, 2023, 4:57pm
17
I have no idea where this migration has come from, but this is the reason the CMS didn’t come up. I don’t think there has ever been a migration of that name in the CMS code.
Was anything done to your installation on the 14th September? 2 days after the 4.0.2 release, but before you upgraded to that I think (looks like that was done on the 15th).
Now that you’ve done this, can you see if you have a file in db/migrations/
starting with 20230914133952
If so, before you try and upgrade again you can rollback that migration:
phinx rollback -e production -t 20230914133952
JRD
October 10, 2023, 8:05am
18
Thanks for your support with this, its a clean install of 4.0.2
I do, this is its contents (doesn’t look to do anything)
<?php
declare(strict_types=1);
use Phinx\Migration\AbstractMigration;
final class V20230914133952 extends AbstractMigration
* Change Method.
* Write your reversible migrations using this method.
* More information on writing migrations is available here:
* https://book.cakephp.org/phinx/0/en/migrations.html#the-change-method
* Remember to call "create()" or "update()" and NOT "save()" when working
* with the Table class.
public function change(): void
Running the command gives me
D:\WebSites\SHRXibo\xibo>php vendor\bin\phinx rollback -e production -t 20230914133952
- D:\WebSites\SHRXibo\xibo\db\migrations
using environment production
using adapter mysql
No migrations to rollback
All Done. Took 0.1008s
dan
October 12, 2023, 4:42pm
19
This is a tricky one to recover - when you upgrade to 4.0.3 that migration file is removed and you end up with the “missing migration” message. This is because the migration is in the table called phinxlog
but no longer on the file system.
I think the only way to recover would be to connect to your DB and manually delete the row for that migration in phinxlog.
Another way to solve it would be to always copy that file back in again; this is going to be a pain though.
I have no idea how that migration got there in the first place, sorry.
JRD
October 13, 2023, 7:14am
20
