Xibo 3.3.2 installtion on xampp 3.3.0 to many redirect error web/install/
Dear Team,
I am trying to install xibo 3.3.2 on xampp 3.3.0 on window 10 by downloadin open soure file of xibo . But after putting xibo source file in xampp/htdocs and i am trying to run the file as localhost/xibo/web/install .
there are too manny install/install…install/1 is coming in browser url bar .
after that error is coming too many redirects as given below .
http://localhost/xibo/web/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/1
screen shot is here
.htacces file is
htaccess file for CMS instances running in /
if you are running using an alias or from a sub-folder, please refer to the file in docker/tmp
if you previously set a RewriteBase in here, the file in docker/tmp replaces that approach
RewriteEngine On
fix authorization header
RewriteCond %{HTTP:Authorization} .+
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
requests for api authorize
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_URI} ^/api/authorize/.*$
RewriteRule ^ api/authorize/index.php [QSA,L]
requests that start with api go down to api/index.php
RewriteCond %{REQUEST_URI} ^/api/.*$
RewriteRule ^ api/index.php [QSA,L]
install
RewriteCond %{REQUEST_URI} ^/install/.*$
RewriteRule ^ install/index.php [QSA,L]
all others - i.e. web
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !.(css|js|png|jpg)$
RewriteCond %{REQUEST_URI} !^/dist/.$
RewriteCond %{REQUEST_URI} !^/theme/.
RewriteRule ^ index.php [QSA,L]
i tried by cleraing cookies and caches but same problems.
i am new in xibo and i don’t know how to solve the problems.
thanks in advance .
