Xibo 1.8 Docker Launcher
This might be a silly question, but I’m new to Docker and trying to make the most of it.
Can you tell me if the Launcher file that you’ve got for installing Xibo on Docker can be used in a Windows docker environment?
If not, is it possible to create one that mimics the same functionality for Windows?
Thanks,
Justin
You can’t use it directly on Windows, but you can run it from the Docker shell that is installed as part of the Windows install of Docker.
You’re looking for Docker Quickstart Terminal. You can run launcher from inside that.
