Xibo 1.7.7 Error schedule
I cant schedule anything. I schedule a normal task I choose the display and which layout I want to show, the thing is when I schedule the task everything looks normal, but when Im gone check it it doesn`t show the minutes and if I open it gives me December of 1899.
it does not allow me to upload printscreen the link below is for one drive:
https://onedrive.live.com/redir?resid=CEE40EFA755FDCAC!3089&authkey=!AFJvv2EojkKAua8&ithint=folder%2Cjpg
Hope someone can help me
thank you
What CMS version is this please?
Also I’m quite sure you’re using ‘international dates’, you might want to switch it off and also go back to the default date format Y-m-d H:i if you’ve changed it as well.
Im using now 1.7.8, Ive just updated yesterday from 1.7.7 to see if it would fix the problem but it didnt. Im using xibo since version 1.7.4 and untill now Ive never had a problem with schedule. Only after Ive updated from 1.7.6 to 1.7.7.
And yes Im using international dates, but since version 1.7.4 that I used does setting and never had a problem, Im gone try it.
thanks
