Installation Method
Installing on apache using xampp
Operating System
Windows 10
localhost/xibo is showing directory instead of the installation page
Provide screenshots where possible!
2.3.3
Windows 10
the documentroot in your Apache config file is wrong:
It must be c:\xammp\htdocs\xibo\web
But you can use also http://localhost/xibo/web
Greetings Torsten
Please don’t do that. It’s not secure. You must adjust your document root or locate the Xibo code somewhere outside the document root and use an alias. The installation documentation covers the options:
https://xibo.org.uk/docs/setup/prepare-your-environment
Hi dan,
thank you for your hint, so i know it better in the future.
Greetings Torsten
