running 1.7.4 on intel compute sticks with win8.1. Connected to various TV screens (all full 1080 res) seems if the compute stick boots before the screen is powered up it runs the player at the wrong resolution (looks to be 720). I then need to remote in and re-launch the player for it to detect the correct resolution. Is there any way to force it to run at 1080 regardless of what the detected resolution is?
You can force the size and position the player starts up in from the Player settings, or in 1.7 series with a Display Settings profile. You’d set
Width=1920
Height=1080
Offset Left and Top=0
