Working with different screen resolution
Hi. I am new to this. We have several screens in our building, with different resolutions. Some are 720p, others are 4K or 1080p. Is it possible to use a single layout for all these screens? Or do I need to create a specific layout for each resolution? In my opinion, I should be able to display the same 16:9 aspect ratio on all the TVs, right? Can I resize a layout without loosing its elements? I tried and ev erything goes off screen.
Create one layout per target resolution (720p, 1080p and 2160p), so you end up with three layouts total.
Once a layout is published, save it as a template and use a single shared playlist across all resolutions. That gives you one central place to update media and every layout stays in sync. If you place a widget inside a region, it should scale automatically with the region.
