R303.0
Layout not displaying on player, player resets
Hi I can schedule a layout to a player successfully, however when I try a specific layout that is valid in CMS and runs great in preview it fails to display on a windows player. and in fact the windows player resets ( as in shuts down ) and gets into a cycle where the watchdog opens Xibo and it then fails again about three mins later
found the following in the logs ( Local to player )
2022-04-21 15:43:52MainFormChangeToNextLayout: Layout Change to C:\Users\Front_House_left\Documents\Xibo Library\686.xlf failed. Exception raised was: Failed to compare two elements in the array.
Any help would be appreciated
Provide screenshots where possible!
