which framework is used in xibo project
like Zend,Codeignotor,CakePHP Which framework is used in xibo project?
Currently none of the above. The 1.8 series is based on Slim and Twig.
what technology exactly used in xibo project
like core PHP or PHP OPPS concept or any Other?
i think you have included Bootstrap in your xibo project.
The CMS is written in PHP. The Windows Player uses .net Framework Windows Forms.
For a list of the libraries used (eg Bootstrap, CKEditor, JQuery etc) you can look in the 3rd party directory of the source code:
Thanks Alex Sir
Sachin Jadhao
India
