What is the difference between the (Update) and (Update Interval Images) options in the (Caching) Ticker Guide? "V2"
What is the difference between the (Update) and (Update Interval Images) options in the (Caching) Ticker Guide? “V2”
In the Ticker instructions found here:
The function of these two options is not clear.
01) Could you explain more clearly the difference between the two?
02) If I set the 1st or 2nd option in 60 minutes, does this mean that every 60 minutes XIBO will access the website to download the data and images from the rss feed to the website?
Even if the images have already been downloaded before, will it download again every 60 minutes?
Those options give you the ability to determine how long the Player will keep the data and / or images saved locally before checking for updates. So it gives you the option to set different update frequencies for images and the data.
I will add that information to that page to make it a little clearer :+1:
