I like to know if anyone has previously used DS-100 ( ARM-based DS player from advantech) with Linux platform? Are there any incompatibilities or issues with Xibo? Thanks in advance for your support.
CPU: Dual-core Arm Cortex-A72 processor + Quad-core Arm Cortex-A53 processor
Memory: 2GB Memory on board
Storage: 16GB eMMC on board
GPU: Quad-core Arm Mali-T860MP4
Graphic Engine: OpenGL ES1.1/2.0/3.0, OpenCL1.2, DirectX11.1
I can’t no. Whist the Player is in heavy development it’s not possible for us to give a specific spec that will be good for all use cases.
You’ll need to try it for your specific use case and work from there. I’d suggest avoiding Celeron/Atom based machines (the sticks etc) and go for a reasonable spec NUC or mid range PC. It must be 64 bit and it must be Intel architecture (ie not ARM, RISC etc). I’d recommend minimum 4GB RAM.
