Since 2018/19 we used Xibo on different android devices. Unfortunately we received the same notification ‘Xibo is not responding. Would you like to close this app?’ on a daily basis. Therefore we decided to switch to Windows which is a much better option. However, I want to give it just one more go before I throw the towel in the ring. So, what I tried is the follwing:
I have used 3 different android boxes, Scishion v88, NexSmart and Xaomi.
I have used Android 5.1 and 6.
I have used paid licenses 1.7 and 1.8 client based players. I even tried the newest client version for a week (even though the client said I could use it for 14 days, I received the ‘license pool’ message after a slim 7 days.
I tried using the internal memory and external memory, both of them gave me the same old message.
The log file states “Application Not Responding detected. E = Application Not Responding”.
Every time the error appears, I fully need to restart the android device. I tried emptying the cache, but that doesn’t work either.
I read several other forum articles that contains the same issues. But none of the solutions offered worked for my situation.
I even used a layout with a simple rss feed, the problem still occurs.
I tried enables and disabling the ‘clear the cached data’ option. No effect.
The layouts I’m using consists different areas, one of them has google slides and youtube videos (1000x600 pixels), they all work perfectly on my Windows pc’s, I’m using an Acer Veriton model N282G on 720p for all of the locations. All of them have zero problems (and free licenses?). And the crashes occur on different moments.
Is there anything else I’m able to do to make it happen? It’s not about the licenses I purchased, even though my feelings are that there are a lot more people having problems with android clients than pc clients. But right now I don’t have any clue what could be the issue. Thanks.
