How do you connect adb to the android device? I’ve had similar problems sometimes if I connected via USB but if I connect adb via network IP address I can always debug webviews in chrome:
adb connect x.x.x.x:5555
Not sure if it’s related to your issue but hope this helps.
Regards.
I’d like to clarify what I’ve said. So, I can connect remotely to ADB, via USB or TCPIP. If I open the android browser, debug it without problems, but when I run the xibo instance, it doesn’t appear to be able to debug.
As with most production APK’s we don’t distribute a debug-able build of it, essentially we have WebView.setWebContentsDebuggingEnabled(false); which is the default.
I appreciate this might be a frustrating experience, but I do not think it makes sense for us to allow it for security reasons.
If you’re able to contact our support desk, and link to this topic, we might be able to help you debug (if we can have the code you’re trying to embed).
