Installation Method
Docker (docker-compose version 1.25.0, build unknown)
Operating System
debian 11.6
I´ve a fresh install of xibo docker at my debian 11 virtual machine and I´m using the internal webserver with port 80. After running some time I can´t access the web interface any more because a get an 404 error of the docker webserver. Also the players are disconnected (error mail is sent).
I don´t know, what possibly could cause this problem. I´ve already disabled memcache, but it doesn´t seem to be the problem. This is my docker-compose yml:
version: "2.1"
services:
cms-db:
image: mysql:5.7
volumes:
- "./shared/db:/var/lib/mysql:Z"
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 1g
env_file: config.env
restart: always
cms-xmr:
image: ghcr.io/xibosignage/xibo-xmr:0.9
ports:
- "9505:9505"
restart: always
mem_limit: 256m
cms-web:
image: ghcr.io/xibosignage/xibo-cms:release-3.3.4
volumes:
- "./shared/cms/custom:/var/www/cms/custom:Z"
- "./shared/backup:/var/www/backup:Z"
- "./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z"
- "./shared/cms/library:/var/www/cms/library:Z"
- "./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z"
- "./shared/cms/ca-certs:/var/www/cms/ca-certs:Z"
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
- CMS_USE_MEMCACHED=false
- MEMCACHED_HOST=cms-memcached
ports:
- "80:80"
mem_limit: 1g
cms-memcached:
image: memcached:alpine
command: memcached -m 15
restart: always
mem_limit: 100M
cms-quickchart:
image: ianw/quickchart
restart: always
Docker logs of the cms container says:
Importing ca-certs
cp: can't stat '/var/www/cms/ca-certs/*.pem': No such file or directory
cp: can't stat '/var/www/cms/ca-certs/*.crt': No such file or directory
WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
Setting up Quickchart
Configuring Maintenance
crontab: can't open '/etc/crontabs/apache': Permission denied
Starting cron
Starting webserver
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using 172.18.0.5. Set the 'ServerName' directive globally to suppress this message
Xibo is hosted on an internal vm, so no https is configured.
