Webpage https://bing.com/covid is not displayed on player version 204.
In the CMS preview it is displayed normally.
Is there any specific configuration for this webpage to work on the player?
Something wrong then ?!
I have to use a player with the most current android version to run some website´s of the “webpage” widget, however my player must have Android version 6.0 or earlier for the xibo for android application menu to be displayed.
So it gets complicated!
Do you have a forecast for when the menu problem that does not appear in the most current versions of Android will be solved?
There’s no problem with Xibo for Android’s menu. There are devices which incorrectly hide menu buttons in all apps that use the standard Android menu system.
The DSCS9 is Android 6 or 7 and doesn’t have problems with showing menu buttons, nor does the generic Android images provided by Google.
You need to speak to your device manufacturer and ask them to stop hiding menu buttons in their firmware unfortunately.
