Good news the codec configuration was not correct. I have installed K lite codec pack standard and wmfdist and now the video work. I think that if i install VLC all is correct but is not true it’s normal without the good codec…
Please i search on the net and never see this solution where i can found a good document explain specification and parameter.
Sorry for my poor english
Good day for you and thank’s a lot.
Eric
VLC has it’s own codecs built in. Klite codec pack installs codecs into Windows itself which allows other applications to leverage them - such as Xibo.
