Im using WebHook to trigger layouts from a tablet with X4A with HTML webapp.
however, the default behavior seems that the player returns the default (or scheduled) layout when it finish to play its duration.
is there an option to maintain the triggered layout to play in loop untill i trigger something else ?
The behaviour you are seeing is correct. The webhook will trigger the layout displaying, then will return to its original layout/media once the trigger layout has finished. It is not currently possible to have the triggered layout continue to play in a loop until another another web hook is triggered.
Thanks, i will post a feature request.
meanwhile, if anyone looking for this behaviour: i have set the triggered layout duration long (3 hours) by setting custom time for the video and setting the region to loop.
