My example might be not very important, but I like ‘hidden features’ in Xibo as the one I did use here.
I made a weather page to show nearly all data from Open Weather. Then I realised, that I could use my own pictures as background, in the preset they were predefined according to the weather. The company I work for has a few webcams running, so I use the URLs from the webcam as background, and they are changing when the weather is changing.
Hello @natasha, I did the CMS update to 3.1.1 and now I do not find the possibility to use a URL as background picture in the new weather module.
Is it no longer possible or do I just not realise where to find it?
The intention is to use library media rather than image by URL as the images would not be stored locally on the Player and will break if the device goes offline. However, it is still possible using the options below:
To use the same image regardless of the weather, use the Background Image dropdown and set to None:
