For some reason in the latest version (4.1.0) I can’t find the area where an API connection can be set for the weather widget,
I would love to receive guidance on how I should configure the widget in the current version.
thanks!
thanks!
I am also facing the problem in weather plugin in the latest version 4.1.0
API setting for weather moved to the connectors which you may find under Admin >> Application menu
API key setup already done API key also working on another application, but in this application not working.
