Where can I find the weather widget in Xibo 2.0.2?
I imported some layouts from a different Xibo version wich inluded a weather widget and now I can’t see or add the weather widget.
First ensure that the Weather module is installed and enabled: https://xibo.org.uk/manual/en/media_modules.html
https://xibo.org.uk/manual/en/media_module_weather.html
Please note that in earlier versions the Weather Widget was also known as Forecast IO.
If after checking you are still having issues then please do come back to us.
Thank you
Thanks I completely forgot to install the module.
Hello All,
By my side i can’t see any Weather Widget from my CMS 2.3.8. In the module list i can’t see any Weather Module listed. I also don’t see “install module” button.
Should I need to install “Custom Module” for the weather widget or does exist a read to use module for this ?
Please do take a look at the solution in this topic here:
